- Joined
- May 10, 2015
- Messages
- 38
- Reaction score
- 4
- Points
- 8
Hi all,
Would appreciate some guidance on this one. Decided today was going to be a good day to do a standard car check (oil, fluids and such). Found my rear wiper wasn't spraying any washer fluid. Odd. Read around on the subject and from what I've found its probably the washer fluid feed has degraded/uncoupled from the wiper motor and so it needs reattaching. OK no problem, popped off the rear trim and found the motor and tested out the washer to see where it was leaking out...It wasn't where I was expecting.
I found the leak to be coming out from inside the wiper motor (in the join between the outer metal plate and the plastic casing, see 1). It also slowly leaked out of area 2, but at a much slower rate. When the boot was closed, no leaking occurred, it only came out when I opened the boot fully and let gravity do the work. Is this normal? Is this something I can still fix or am I going to need a new wiper motor? :/
