According to ETKA the recommended oil is G052 911 the A1 or A2 on the end just means 0.5 or 1L bottle. A1 is 0.5L , A2 1L .
It's hard to tell who makes the OE oil, I couldn't find an exact match for G052 911 when I changed the oil in mine so got it from the dealers. some people seem to have had positive outcomes changing oil for thinner stuff, some not.
Buying it from the dealers is about twice the cost of getting something like Fuchs from Opie or Fleabay.
I did some basic testing, lots of research and ended up buying the genuine stuff from my local Skoda dealer.
I was looking at an older copy of ETKA I have on my PC and it showed the same gearbox oil for all the quattro gearboxes, 0B2 and 0B4 .
When looking on line at what I believe is a newer version of ETKA it show different oil for the 0B2
Yes that is probably correct, wonder what is so different between 0b2 and 0b4 on 0b4 you have a more conventional oil but on 0b2 it is only the VAG oil and Motul DSG oil.
Maybe that the reason for these transmission having synchro problem(at least mine have) because it uses strange oil.
If i drive like now it will eat the synchro ring on second gear that is for sure
On the 0B4 they have triple cone synchronisers on 1st and second and dual cone on 3rd-6th.
On the 0B2 they have only a triple cone on 1st , dual cone on second and a single cone 3rd to 6th.
So the synchronisation capability of the 0B2 box is not as good as the 0B4 . It's possible the oil was changed to something that would help the synchronisers.
The OB4 is a Getrag box, or is made under licence by Audi , where as the 0B2 is an Audi box made in the gearbox plant at Kasse
