As previously reported I have just bought a Transcend DrivePro 200 also and used it for the first time today. I bought the Transcend suction mount as I didn't fancy using the stick on version. I took the power lead (temporarily) behind the sunshade, down the windscreen edge into the glove box and into the 12v socket. This was just to see what it was like before I committed to more permanent wiring. Contrary to people with Blackvues (I think that's the model) there is no interference on the radio in either DAB or FM and whilst I haven't downloaded the files yet I'm impressed. I switched off the G-sensor (or was the G-Spot!) as received wisdom is that it switches itself too often what with the state of our roads. The emergency button is sufficient as a press on that and the DrivePro records data 10 seconds before and 50 seconds after an event occurs (total 1 minute). The DrivePro can save up to 15 emergency video files and these files are protected from being overwritten.
I have also switched off the sound recording as I don't want a record of me cursing the stupid driving of my fellow motorists!!
I've set the recording duration to 3 minutes for no other reason that it was in the middle of the 3 options 1, 3 and 5 minutes. Has anyone any opinions as to which is best and why?
So, it gets my vote but I'd like to neaten up the wiring and get rid of the chrome lens surround. Perhaps a Matt black wrap would make it less noticeable? Any ideas where to buy?
So the transcend 200 comes with front and back cams?
Excellent, so now all you need to do is a nice write up with loads of pics ready for when mine arrives ( tomorrow ) and the car ( by this weekend ).
The 1,3,5 minute thing is just so you can quickly find and save the footage. I'd say 3 is about right, not sure what the lag time is ( if any between clips ).
I was going to power mine from the glove box as didn't want a cable going into the cigarette lighter, that's for my Audi torch.
Got any pics of where its installed, I was going to mount mine behind the mirror if possible.
Been away working at the NEC so only just seen your post. Camera worked fine on the journey up and back. No pictures yet on the installation as I'm waiting for Hurricane Gonzalo to subside before I venture outside! I have ordered some matt black wrap samples as the only disappointing thing about the DrivePro 200 is the chrome lens ring. It makes it very visible from outside so I plan to "wrap" the lens surround. I'll let you know how it turns out when I get the wrap installed. I have also ordered a 12V to mini-USB 5V conversion cable so I can hard wire the unit into my fuse box using one of these piggyback fuse connectors.
If you use a tap-a-fuse with that cable, does the fuse you piggyback off have to be 3A+3A, or can you piggyback off a 20A + 3A?
That's a good point you've brought up there, like you said maybe a better fuse selection?
What is it fused to at the moment? How about moving it to something like the rear windscreen which would stay on even if stop/start kicks in.
Since you've already done all the hard work, it wouldn't take you more than 5 minutes to move the fuse
Now that's a good idea - didn't think of rear screen heater. Cheers.
So I fitted my hard-wired dash cam at the weekend. (and yes, I have looked through the other threads about fuses!). I've taken the feed for it from fuse 40, with a piggy back connector and all is working fine - well to a point that is. The camera powers up as soon as the ignition becomes live, which is what I want. The camera stays on if I come to a junction and the stop-start kicks in - which is again what I want, but as soon as I hit the throttle to move away and the engine wstrats up, the feed to the camera is dropped for a very short time (milliseconds I suspect) and the camera reboots. It would appear that supply to fuse 40 is being interrupted briefly when starting. It might be specific to this camera (Trancend DrivePro 200) which doesn't have an internal battery?
Now many of the other ign only systems don't show this brief interruption, and you'd be hard pressed to notice it on the cigar lighter, if it was being used at the time, however it is annoying! I'm minded that I could strap a capacitor across the input which might hold the camera on over that time, but the sensible option is a better fuse selection.
Anyone got any other options, or come across the problem?
Thanks Nimbus
As I've semi-permanently disconnected my Stop/Start I don't have the problem with my Transcend unit so unfortunately cannot help. I still have to wire the feed in permanently so at this moment the unit works perfectly - I'm really impressed with the quality and using the accessory suction mount it is rock solid.
How big is the suction mount when compared with the standard mount?
It's about the same size - really neat and at £6 or so it's a bargain. Rock solid video using it too.
I checked this evening - I'm using fuse F44 (Four wheel drive), which isn't present in my car/fusebox, so I just used it.
I guess I'll have to investigate a different one to use! The one next to it is for electric seat adjustment apparently, but I'm not sure the labelling is correct as the manual (p 252 I think) says that it should be a circuit breaker, but a different function (washers system) is labelled as the circuit breaker in that area.
I piggy backed the cigarette lighter fuse.
My camera doesn't cut out at all for S/S.
But then again I don't have a Transcend 200.
I have a Janus HD.
