Hi,
I have been lurking on here a while unregistered, just reading on common issues and mods etc. I've now registered as I need some help with the below issue...
I have a 1998 manual C5 A6 2.5tdi FWD 150 AFB model, approx 120,000 miles (hope that covers it ) that has happily been working fine until last friday.
It started fine and moved about 2-300m, then attempting to move off it just cut out and would not restart. It doesn't even attempt to crank.
I scanned for faults and got:
00550 - Start of Injection Regulation
08-10 - Control Limit Surpassed - Intermittent
I since cleared the error and it now shows no errors when the ignition is on.
Battery power is fine. I have been running a chipped ECU, but I have swapped back to my original ECU (exact same model no.) and there is no difference.
I have tried researching the problem on here and other forums, but with the different models it is hard to pinpoint. My gut feeling from reading the posts is that it's the injection pump, rather than something simple and cheap!
I have vagcom, so if there are any readings or measurements I can take then please do let me know.
If it is the injection pump, are used pumps an option? As I know there are possible coding issues.
Thanks in advance for any help.
Brad
Brad
