Hi all
I have tested the clutch + brake switch with a multi meter and also plugged in and it came out with clutch switch implausable signal ....
Other than that error code i had sensor bank 1 (aparently lambda sensor) and also i have a error code for O2 sensor (MAF) i think this has come on since i put bens S2000 air filter on ...
I then cleared all fault codes
Then when i re-put the clutch switch back in cruise control worked once ... i then hit the brake to dis-engage it and then tried it again and it still doesnt work since.
My question is...
Can the O2 fault code stop my cruise control from working ?
Or if not any other ideas on what could effect cruise control working ?
P.s the bank 1 sensor fault has not returned (Yet)
My question is...
