bosch green top 440cc
Miguel_S#
hello people
can someone tell me the specs of the injector bosch 440cc green top, reference 0280150558
lantency time by the voltage.....
kind regards
its a good thought but the money for the 550cc it be will to others things like wmi, exhaust manifold....
i will do some km with the 440cc
You've been told the same thing on asn and vortex and you ignore it.
THEY ARE THE WRONG INJECTOR.
you wont get specs in either forum because no one uses them
Reactions: Sam_
info from this spreadsheet
Injector type
OE NR.
Type
offer drawing
Resistance (Ohm)
Test medium
Operating pressure (kPa)
Q-stat (at operating pressure) (g/min)
Q-stat with 300 kPa (g/min)
Q-stat with 300 kPa (ml/min)
q-dyn with 300 kPa, ti 2,5 ms (g/1000 Imp.)
Spray type
Spray angle alfa-50 (for 2 beam)
Spray angle alfa-80 (for cone-characteristic)
axial deviation angle (spray bent angle)
Spray orientation angle
Spray distribution (area, spray amount)
allowed fuels
Version, type
Electrical connector
locating lug (anti rotation device)
hydr. connection to manifold
hydr. connection to fuel rail
Distance between O-rings(O-Ring to O-Ring)
Total length
280150558
0 280 150 559
EV 1
CH-XL3E-836-AA
14.5
Heptan
270
310
326.8
466.8571429
10.65
C
23°
8°-20°¤>55%
1.3
Jetronic
no
O-Ring standard
O-ring variant
60.5
77
No idea if its what you're looking for
