2.5TDi Quattro - Rear Brake Size
AlexGSi2000
Well-Known Member
Liverpool
Does anyone know the size of the rear discs on the 2.5TDi Quattro Avant?
Ordering some on ECP, I have two options;
245mm diameter - 10mm thickness
255mm diameter - 15mm thickness
Many thanks!
I would just measure the thickness of yours to be safe........quite easy with a ruler or tape measure through the wheel spokes
When replacing discs and pads it's a good time to upgrade ! Folk use b5 rs4/passat w8 or allroad v8 rear calipers with Trig's brackets and 300mm brake discs, very easy "bolt on" upgrade !
Why you tell me this now! :sob:
dont forget that you do not need to remove the carriers to change the disks. They come out with a wiggle:icon_thumright:
