- Joined
- Sep 14, 2008
- Messages
- 24,836
- Reaction score
- 6,078
- Points
- 113
- Location
- Wibbleton
- Website
- www.tuffty.co.uk
Using standard dv
Do you get like a choo, choo, choo noise if you rev the engine from idle?
Using standard dv
Erm, not really, can just hear the air being pulled in through the filter mainly..
Tuffty do you know of anywhere to get a generic tune that I can plug and play? As not many places here in Australia specialise with Audi's and the places that will tune them charge an arm and a leg
I found the following number on a plate in the engine bay, "WAUZZZ8LZYA014955" is that what you are referring to? I'll have a browse on the nefariousmotorsports forum thanks for that.
edit: I forgot to mention your great pun, extremely relevant
There is no hope for humanity with this level of stupidity
That number is your chassis number... engine code is on a tab on the head... its poking out towards the front of the car on the left as you look in the engine bay... yours is most likely either an AUM or AGU...
NefMoto is mostly centred around american spec cars and more specifically S4's... if you want to learn to flash software in yourself you will find info out about how to do that there along with tools required... there is also good info about the ME7 ecu's...
If you want to learn to 'tune' your car its a good start but.... its not going to be easy, ME7 (assuming yours is an AUM) is very complex...
A jerk....never been called that before, although had much stronger words thrown at me
I will add that to my CV
Good luck with the car..........
