Still no ideas as to where to put axle stands?
Just for completeness - this is from the workshop manual:
Got it. Any pics of where to insert the jack stands? Thanks!Post #82 is where you should jack.
Stands should be placed elsewhere.
They don't want you to diy your own car, but to visit the main dealer instead. Hence, they make it as difficult as possible to jack up and support properly.We seemingly still have no straight forward way of jacking the 8v up and putting it onto axle stands.
I tried jacking up on the correct jacking points with my 2 x 3t trolley Jack's but found that for example, the rectangular rubber blocks attached to the chassis at the rear were too close to the jacking points and trolley jacks to get axle stands anywhere near them. I ended up putting the stands below the rear suspension arms. Not ideal.
What we need is either easily accessible axle stand points when the car is lifted on the standard jacking points by a trolley jack or an alternative place to lift with the trolley jacks enabling axle stands to be used with the standard jacking points.
Is there a decent photo of the underneath of the 8v showing the jacking and decent axle stand points?
Excellent picture. What are the back stands on? The jacking points? If so, how did you get the car in the air to get the rear stands in?I've never had any issues jacking or using axle stands with my S3 8V, no idea what all the fuss is about.
I also am grateful for this picture as I was not confident in putting stands under the subframe.I've never had any issues jacking or using axle stands with my S3 8V, no idea what all the fuss is about.
This is helpful. Thank you.Either or but really depends what you're doing on the car. If I'm working under the front I use two Jack's then two axle stands as its much easier to balance the lifting. Once the front is lifted if I need to get the rear up I very carefully jack under the diff then pop two axle stands either side. Never had any issues or concerns with my method. I've been working on my own cars for years so whatever feels right for you, it's not rocket science so don't over think it.
