ODB Wiring
ScottD3
Supporter
Plymouth
Website
wheelsnwires.blogspot.com
With 3 RNS units sat on my desk, I'm thinking of building a little test rig.
I got power sorted out, need to get some speakers and the diag port done.
The speakers are easy but I'm not sure on the diag port.
Am I able to wiring in a port directly to the rns unit and use VCDS?
Going by this image.
Going by this I assume I get a plug, give it ground and live, then run 7 (K-Line or K1) and 15 (L-Line or K2) to the correct pins on the stereo.
Same as the can-bus if I wanted to use that?
K and L plus power and a vcds search should come up with the rns as the only address, worth a go anyway
problems might occur with canbus as missing node numbers so you would need to simulate the nodes to get the data flowing correctly, not worth the bother IMO
Old school K-Line it is. :thumbsup:
488
926
9K
755
951
