Audi S3 2008 help / advice needed
badsal
West Yorkshire
First of all hi everyone hope you all had a good christmas. I'm new to this forum so don't wanna make any mistakes or post in the wrong section, last night after a normal drive at the lights as I was stopped the mil light popped up got it connected to vcds and its showing me 12 faults but some are quite old I have for the reading saved am I allowed to post it on this section so you guys can have a look and help me please?
thanks
thanks
Yes, post the logs and someone will come along to help.
Before you post the log make sure you have saved it first and then try to clear the faults.
Maybe some of them will go away.
p.s. welcome to the forum !
Friday,28,December,2012,13:21:24:13314
VCDS Version: Release 908.0
Data version: 20090911
12 Faults Found:
001089 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 002 - Lower Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 10
Mileage: 85660 km
Time Indication: 0
Date: 2012.10.22
Time: 22:12:27
Freeze Frame:
RPM: 840 /min
Load: 16.1 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 16.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.097 V
008853 - Fuel Pressure Regulator Valve (N276): Short to Ground
P2295 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Mileage: 91448 km
Time Indication: 0
Date: 2012.12.16
Time: 22:28:26
Freeze Frame:
RPM: 764 /min
Load: 39.6 %
Speed: 14.0 km/h
Temperature: 87.0°C
Temperature: 24.0°C
Voltage: 14.224 V
001092 - EVAP Purge Control Valve (N80): Circuit Open
P0444 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Mileage: 91448 km
Time Indication: 0
Date: 2012.12.16
Time: 22:28:27
Freeze Frame:
RPM: 814 /min
Load: 32.1 %
Speed: 16.0 km/h
Temperature: 87.0°C
Temperature: 24.0°C
Voltage: 14.351 V
000051 - Turbocharger Bypass Valve Control Circuit: Malfunction / Open Circuit
P0033 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91448 km
Time Indication: 0
Date: 2012.12.16
Time: 22:28:27
Freeze Frame:
RPM: 814 /min
Load: 32.1 %
Speed: 16.0 km/h
Temperature: 87.0°C
Temperature: 24.0°C
Voltage: 14.097 V
000579 - Solenoid Valve for Boost Pressure Control (N75): Malfunction
P0243 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91448 km
Time Indication: 0
Date: 2012.12.16
Time: 22:28:27
Freeze Frame:
RPM: 814 /min
Load: 32.1 %
Speed: 16.0 km/h
Temperature: 87.0°C
Temperature: 24.0°C
Voltage: 14.097 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Malfunction / Open Circuit
P0030 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91448 km
Time Indication: 0
Date: 2012.12.16
Time: 22:28:27
Freeze Frame:
RPM: 814 /min
Load: 32.1 %
Speed: 16.0 km/h
Temperature: 87.0°C
Temperature: 24.0°C
Voltage: 14.097 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Malfunction / Open Circuit
P0036 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91448 km
Time Indication: 0
Date: 2012.12.16
Time: 22:28:27
Freeze Frame:
RPM: 830 /min
Load: 27.8 %
Speed: 16.0 km/h
Temperature: 87.0°C
Temperature: 24.0°C
Voltage: 14.224 V
008200 - Intake Manifold Flap; Bank 1: Electrical Malfunction
P2008 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 91566 km
Time Indication: 0
Date: 2012.12.17
Time: 19:07:39
Freeze Frame:
RPM: 3118 /min
Load: 31.8 %
Speed: 25.0 km/h
Temperature: 83.0°C
Temperature: 21.0°C
Voltage: 14.224 V
012600 - Intake Manifold Runner Control: Regulation Deviation
P3138 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 1
Mileage: 91566 km
Time Indication: 0
Date: 2012.12.17
Time: 19:07:39
Freeze Frame:
RPM: 3118 /min
Load: 23.5 %
Speed: 25.0 km/h
Temperature: 83.0°C
Temperature: 21.0°C
Voltage: 14.224 V
000136 - Fuel Rail/System Pressure: Too High
P0088 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 91886 km
Time Indication: 0
Date: 2012.12.22
Time: 13:04:54
Freeze Frame:
RPM: 2140 /min
Load: 11.8 %
Speed: 20.0 km/h
Temperature: 86.0°C
Temperature: 30.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.589 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336): Open or Short to Plus
P1098 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91980 km
Time Indication: 0
Date: 2012.12.22
Time: 15:03:12
Freeze Frame:
RPM: 1793 /min
Load: 65.1 %
Speed: 34.0 km/h
Temperature: 88.0°C
Temperature: 23.0°C
Voltage: 13.843 V
012599 - Intake Manifold Runner Control: Basic Setting not Completed
P3137 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91982 km
Time Indication: 0
Date: 2012.12.22
Time: 22:59:42
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 19.0°C
Temperature: 17.0°C
Voltage: 11.684 V
Readiness: 0000 0000
Just as a matter of interest is that VCDS genuine ? If so you need to update because the current version is 11.11.3 !
Someone will come along to help but I can't I'm afraid due to not knowing anything about the petrol engines !
you need to clear the faults then see what one reappears as the intake flap has popped up a few times that may be the cause for all the other faults?
Have cleared faults and been driving today bout an hour ago epc light come on turned car off an on light gone only loss power when light came on
ye you will loose power because the car will go into limp mode to protect the engine from further damage its like a fail safe clear faults re-scan and let me know faults that reappear
Car driving normal at the moment no lights showing on dash will get my freind to connect vcds again tommorow to read faults and il update then thank you for all ur help so far
These are the new faults
Address 01: Engine (CDL) Labels: None
Part No SW: 8P0 907 115 AB HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H8FN40QQ
Coding: 0103000C180F0160
Shop #: WSC 00673 210 83197
8 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92499 km
Time Indication: 0
Date: 2012.12.28
Time: 17:27:06
Freeze Frame:
RPM: 1727 /min
Load: 26.7 %
Speed: 45.0 km/h
Temperature: 88.0°C
Temperature: 30.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
001112 - Evap System Purge Control Valve (N80): Short to Ground
P0458 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92499 km
Time Indication: 0
Date: 2012.12.28
Time: 17:27:07
Freeze Frame:
RPM: 1727 /min
Load: 12.9 %
Speed: 45.0 km/h
Temperature: 88.0°C
Temperature: 29.0°C
Voltage: 13.970 V
000052 - Turbocharger Bypass Valve Control Circuit: Low
P0034 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92499 km
Time Indication: 0
Date: 2012.12.28
Time: 17:27:07
Freeze Frame:
RPM: 1727 /min
Load: 12.9 %
Speed: 45.0 km/h
Temperature: 88.0°C
Temperature: 29.0°C
Voltage: 13.970 V
000581 - Solenoid Valve for Boost Pressure Control (N75): Short to Ground
P0245 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92499 km
Time Indication: 0
Date: 2012.12.28
Time: 17:27:07
Freeze Frame:
RPM: 1727 /min
Load: 12.9 %
Speed: 45.0 km/h
Temperature: 88.0°C
Temperature: 29.0°C
Voltage: 13.970 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Short to Ground
P0031 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92499 km
Time Indication: 0
Date: 2012.12.28
Time: 17:27:07
Freeze Frame:
RPM: 1727 /min
Load: 12.9 %
Speed: 45.0 km/h
Temperature: 88.0°C
Temperature: 29.0°C
Voltage: 13.970 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Short to Ground
P0037 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92499 km
Time Indication: 0
Date: 2012.12.28
Time: 17:27:07
Freeze Frame:
RPM: 1727 /min
Load: 18.0 %
Speed: 45.0 km/h
Temperature: 88.0°C
Temperature: 30.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 92500 km
Time Indication: 0
Date: 2012.12.28
Time: 17:32:12
Freeze Frame:
RPM: 1254 /min
Load: 31.0 %
Speed: 10.0 km/h
Temperature: 87.0°C
Temperature: 35.0°C
Voltage: 13.843 V
004688 - Fuel Level too Low
P1250 - 008 - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 92500 km
Time Indication: 0
Date: 2012.12.28
Time: 17:32:13
Freeze Frame:
RPM: 1451 /min
Load: 37.6 %
Speed: 12.0 km/h
Temperature: 87.0°C
Temperature: 35.0°C
Voltage: 13.589 V
Readiness: 0000 0001
under ur engine cover on the right hand side you will see the fuel pressure regulator sensor make sure that isn't broken as ive had a few of them that brake this could be the problem
Hi can you point out which it is ImageUploadedByTapatalk1356794488340977
Hi just found the sensor it's got a crack all the threw ImageUploadedByTapatalk1356795658733091
How much is this sensor and where is it best to buy from
Regards
How much will be the HPFP? Also do u guys think after I change that it should clear the other faults too?
Regards
thats it mate they are common but exspensive to replace main dealer part only
thats it mate they are common but exspensive to replace main dealer part only you can unbolt that sensor from the new pump and fit to the pump thats on the vehicle you will need to have the fault codes cleared once again but be careful when fitting engine cover as it may break it again put grease on rubber grommets to allow the cover to go back on alot easier
Thanks for you help guys I shall give audi a call on Monday and once I fit it in I shall erase and see if anymore faults crop up
653
781
TM
