Wellycooler Help
IrishDave
Dublin, Ireland
Ok I know quite a few people have fitted these to their cars. What I want to know is where did you relocate the horn to? and how. Did you use the normal bracket or make a new one up.
Thanks.
Haha I was going to say man power, I have an a3 so I don't know how different it is on an s3
They are... bracket is already under passenger side wing where the second SMIC would go on an S3
I just bent the bracket and fitted it back.its touching the intercooler pipe but it will be ok :)
Right thanks for that. Next problem. I am having an absolute nightmare trying to get the bumper back on. The cooler is sitting too low and because of the bracket on the drivers side where the old charge pipe mounts to it will not raise any higher. At the moment the pipes from the end tanks are sitting lower than the grilles and fogs. Any ideas. Pleassseeee
You will have to butcher the inside of the bumper.try trial fitting it then seeing where it makes contact.its mostly the lower part that needs trimming.thetop should be fine.may have to.trim the vents down too.get a pic up
762
14
10K
