headlights
wot inside car all ive got is instrument dimmer control is my headlights auto adjusting got xenon head lights standard with car
If you have OEM xenons factory fitted then you can't adjust the headlights from inside the car. The self-levelling sensors do that for you. If the sensors are goosed then the beam height may be wrong. Use VCDS to set the lights to MOT test position and have the beams tested.
wots vcds
£250 quids worth of diagnostic equipment. Plenty of members on here have it and there is a user map (do a quick search) of people so you can find one near you who will help. Otherwise take it to a VAG specialist and have it done.
583
596
389
NHN
564
NHN
