2005 3.2 upgrade speedo clocks and change from red to White bulbs? Speedo experts plz
aga54321
Newbury, Berkshire & Swindon, Wiltshire
Hi everybody,
I have a 2005 3.2 fitted with an s3 speedo with red lighting (must be older type)
I would like fit/fit: the speedo mph is out by 10mph depending at what speed your going and I also want to upgrade the colour to White (new s3 style)
Just wondering if anybody can give me some help or contacts which I'd be very grateful for.
Thanks for taking the time to read
Contact Nigel (NHN) on here, he'll be able to help.
Your speedo should not be out by 10mph, something must be wrong...
I wonder if you can adjust the tyre circumference in VCDS, as if the car is running different sized wheels to what was on it from new it will misread.
I'm sure when I installed Navigation unit within the set up menus you had to set a tyre circumference figure, so worth checking.
I don't understand...you changed the instrument cluster to a complete S3 instrument cluster? A picture would help me understand. Are your needles red or white?
Changing to white means white needles and changing the LEDs to white on the speedo and tacho of which there are 2 each. You can de solder and purchase new plcc LEDs. the procedure is as follows
How to remove / solder a PLCC LED for gauge / hvac work PICS - Scionlife.com
I must assume your DIS is red as well so kinda confused as to what look you are after as the DIS and other info will need to be changed to white too.
From memory its an 8P2 cluster with red digit odometer / DIS, but white needles. I think he wants the ODO/DIS in white (not red), and the speedo calibrated.
This is a mod ive looked into and from what i can tell depnding on the year its not a simple mod at all, on mine as its a 2004 i will need a new wire running from the back of the clocks to the fuel pump which also needs replacing for a newer unit. NHN has done this mod like others have said. Its easier on newer cars but he will know all the details which cars have what etc and what needs upgrading, canbus gateway is probably on the list too.
Thanks Warren, I needed an interpreter. So with that, I'm out. Sounds like a consultation is needed by Dr Nige, our resident Audi surgeon!
602
15
NHN
