Hi guys had the tqs for just over two years now. Initially bought as a stop gap after selling my ST. Up until recently everything has been good. But since the first fault it hasn't stopped and concerned I may be throwing money at a dead horse.
Fault 1 - Suspected feul pump (according to RAC). Started and then stalled after a couple of minutes. Would start straight away again but if left for a period of time it would. So car went into garage had feul pump replaced and still wasn't 100% when it came out. I had asked the garage to check MAS sensor first but he insisted it was OK. So I took the car any after shelling some hard earned cash. Within two miles of leaving the garage it decided that it would over heat, cracking the temp sonsor housing. It then went back to said garage and he then informed me that he thought it was the Head gasket (0.0 "really?" do you know anything about audi's I asked) he informed his Audi trained foreman was 100% sure. At this point I took the car to another garage. An audi specialist who agreed that it was more likely to be the water pump that was the culprut. After removing the pump it was confirmed, impellor was gone. Put it all back together and hey presto still got the over feulling fault which turns after diagnostics was the MAs sensor.
Now the car has been running like a dream since then. But! another fault has cropped up.
Fault 2 - The car is running cold now with the temp gauge barley moving off 60. The oil temp is running around 100. Also had the oil pressure light come on once but hasn't come back on since.
Spoke with the garage that got it running proper last time and they reckon it might be the oil pick up pipe gauze getting blocked but thinks it could be the oil pump (never heard of an oil pump failing on these).
With all that has gone on is it possible that it is simply just the thermostat/temp sonsor (all new 2 months ago) failing?
Could this fault cuse the oil pressure to come up low intermittently?
It's a 99 1.8TQS and has done 161k - had oil and filter change recently and is running 5w30 oil.
Any help or advice would be great.
Ken.
Ken.
