B Pillars and Plastic
ScottD3
Supporter
Plymouth
Website
wheelsnwires.blogspot.com
I'm slowly making my way through the little jobs that needs doing on Audrey since most of the big jobs are done (for now).
One little annoying job is the B pillar on the passenger side.
Someone tried breaking in by shoving a screw driver (I assume) in the top right corner of the passenger door and tried to bend the top of the door out to get in.
They never got in but damaged the door, B pillar and the little bit of plastic next to the B pillar.
How do you replace the B pillar?
Can the plastic be replaced at the same time?
b pillar is held on with two screws at the bottom.
Not sure about the plastic, cant think what that is.
Scott,my breaker has the bit of plastic you are on about,I also have a gloss black b piller if you need it
tony
nah,still got it mate!
Just aswell,have broken a couple of bits this week while stripping Vinnie.
Yeah,thats the bits I have,will try and remove the drivers side first,see if it breaks or not lol
tony
tony
The metal bits should be ok.
Just the bolts rounding off of the plastic clips at the bottom snapping.
If you are able to get the plastic bits off, bolts, clips/hinges all in one peace with out breaking.
I'll have them from both sides please mate.
As for the plastic bits, I got no idea how that comes off.
No idea if its one single bit in that corner or a massive unit that goes round the door.
Interested to know.
the plastic bit just covers both top corners of the door shut,so not too big
tony
any ideas how to remove the similar trim behind the rear doors Scott, on the avant
The C pillars?
The are pop riveted in.
One of mine has started to bubble at the bottom.
not wanting to remove them. No idea how they are removed or how they effect the window and rubber.
Not too bad so, was thinking of getting all these pillars wrapped on mine.
Lots of little scratches and swirls
