Hit and miss boost HELP
Si22A4
I had no boost with a fault of low boost pressure. Had my turbo re-conditioned new de cat pipe and everything works fine sometimes. If you accelerate sometimes there's no boost if you let of the throttle and go back on boost is there. Changed the boost sensor and still the same problem. Do you think this is electrical fault or mechanical ? My car is Audi A4 115 se 2000 model. Many thanks
check all the vacuum pipework is intact with no splits/leaks and make sure the VNT actuator on the turbo is free to move.
If those check out then look at a new N75 valve.
I think it might be something to do the vacuum pipes as there was a big rumble and its blown off my exhuast gasket, what do you think? many thanks
I had a problem and it blew off my exhuast gasket. do you think this has something to do with the vacuum pipes?
50
3K
JS4
25
