HELP!!!!!!
supersando
If anybody has a 2000 Sudi S3 then you will hopefully be able to help me. I have managed to break the small compartment in the centre console of my vehicle. I'm talking about the drop-down compartment which hides the cigarette lighter. I can't get it to close anymore and the only thing that I can find is a small piece of rubber which has fallen out from somewhere. Does anybody know how I could sort this out??????
New ash tray or do what i did. Take the ash tray out and youll see that the back has cracked and a metal pin has come out, i bonded the pin and plastic together and its been fine for about 8months, the pin holds the ash tray front up, it locls into a tiny mechanism.
Ok thanks Dani_B19 I’ll see if that sorts the problem.
Turn the caps off!!
(its seen as shouting)
EDIT** Sorted it Nilz ;P <tuffty/> **EDIT
They break after time. A replacement from Audi is around £40. I know this as mine did the same. You may need a new piano trim too as the two parts are separate.... and removing the piano Trim you have from the current tray results on the plastic lugs breaking.
Greg unless your a gorillla u shud be fine.
Maybe... But I bet it will break. Designed to be put on once. The piano trim has three lugs on the rear which clips to the fascia of the plastic compartment tray.
23
900
17
804
