richieb138
Hi Guys,
I'm having a problem with an irritating misfire with the throttle floored, usually around 4k and especially in the higher gears.
I had the problem when I first got the car, and a new ignition coil from the free recall fixed it...... for a few months or so. Slowly, it came back, and gradually got worse until it happened almost every time under certain conditions. I tried swapping each coil for a new one to find the bad one but it didn't show itself so I replaced all four coils and it 'almost' went away, i.e. it didn't happen too often and was much less severe when it did happen. Slowly it got worse again until it was happening all the time again and quite badly, so i figured that I must be killing my coils somehow.
I noticed that the insulation around the wiring across the top of the engine to the coils was a bit knackered so i replaced it all and got all new connectors and four new coils again, hoping that all would be cured, but no, i'm back to it being much less frequent and not too severe again.
Any ideas on where to look next would be much appreciated, although i'm pretty sure it's got something to do with the ignition coils because I get a very obvious improvement (even a complete fix the first time) when I replace them.
