S3 4 Bar Fuel Pump -> Bora 4motion
Y
Yohan87
Guest
I have a Bora 4motion with an AMK lump up front and my old V6 pump is on it's way out.
Do the S3's use a 4 bar pump like the Leon Cupra R's?
I'm not sure if the LCR pump would fit the Bora tank due to the different shape to allow for the Haldex/Diff but if the S3 one uses a 4bar pump then it might?
I recently bought a new S3 Fuel pump but I cant remember what rating it was. Drop Jason.s a PM and ask him as he works in the parts dept. at VW and will be able to tell you what pumps will fit the Bora.
The S3 fuel pump is the same (internally) as the LCR but there are differences due to the S3 having to balance across 2 sections of fuel tank...
S3 pump should do want you want...
Not to be confused with a 4 bar FPR which is not what you want as there is no reason to run one over a 3 bar FPR :)
Many thanks guys :)
Westy, apparently this one was supplied to you?
8L9919051G
Can you confirm that the part number above is for an S3 4 Bar fuel pump?
853
20
4K
851
DPM
