Not sure about the connector being yellow but its easy to find just a little awkward to remove. It's just above the headlight bulb fitting & you should just be able to pull the holder out with the bulb attached to it. Hope this helps you out mate.
the side light connector is above the main beam take off the cover and gently pull the wire it will pop out easy enough to refit look through the front of the headlight so its easyer to line up with the hole for the bulb to go in easy will take less than 5 mins to do
thanks guys
I was actually looking for the plug for the whole headlight unit don't know why i typed it wrong, found it anyway.
Changing the sidelight was a b**ch too messed up my hand!
