Part Number List.
markthenewt
Hinckley
Hi.
Does anybody have a part number list as I need to order a few bits and bobs for when I put the new turbo on?
Cheers.
What bits do you need and what engine code are you and i'll look them up if you want mate?
That would be awesome mate as I have no car at the moment until mine is fixed so hoping Audi or other places could send them to me in the post.
I need a lot lol, no rush though as the car won't be fixed for another couple of days.
Turbo to manifold gasket
• Turbo to down-pipe gasket
• Manifold to block gasket
• Oil line to oil sump gasket
• Oil line to turbo gasket
• O-ring if you reuse your TIP
• Crush washers for banjo fittings on: (make sure
to get 3 or 4 extra of each size)
ƒ Coolant line on bottom of turbo x2
ƒ Coolant line on top of turbo x3
ƒ Coolant line on block x2
ƒ Oil line on top of turbo x2
I have just copied and pasted this list of parts from the guide I am working from.
Is there no where I could check part numbers myself?
Cheers.
Try this site mate VagCat boards i think you have to register to use the parts catalogue but its free. It should give you all the part numbers you need
Ok mate let me know if you have any luck if not i'll look into them. I work for audi in parts so if you want I can organise all the parts minus a little bit of discount and send them out to you?
Cheers Luke I shall let you know, doing a bit of ebaying at the moment and got my eye on a few bits on there.
512
MPH
622
712
734
