Wheel bolts
monty77
Hosrham, West Sussex
Website
www.s3.adam-m.co.uk
What size bolts are in my wheels right now?
...replica RS6s if that makes any difference.
Need some longer ones, going to ask Rochford 1st should they ever answer their ****** phone!
Cheers,
Adam
27.5mm i think were factory for the s3
i uses a 42mm locking wheel nut with my oem wheels and 10mm spacers
[ QUOTE ]
[/ QUOTE ]
Cheers Dunk ... just ordered a set of 16 50mm bolts and a set of matching lockers from Rochford. Trimming may be required though.
Cheers!
Adam
50mm might catch on the suspension behind the hub - you probably will have to trim them
[ QUOTE ]
[/ QUOTE ]
Thought as much ... only did 40mm or 50mm lengths though /ubbthreads/images/graemlins/frown.gif
Cheers,
Adam
Just bought some new RS4 reps and was wondering if the Audi locking nuts R Ok or would any of you recommend using different ones /ubbthreads/images/graemlins/confused.gif
/ubbthreads/images/graemlins/beerchug.gif
[ QUOTE ]
[/ QUOTE ]
Taffy, there isn't many key combinations on the Audi locking nuts (7 i think?) so you should get yourself over to halfords and get a set of McGuards. They are about £30 and are supposed to be one of the best!
I have them on mine and I know a lot of people on here have them.
Go get them before some scroat robs your alloys!
Rich
mcguard do one that is 44mm long with the audi type of head - these fit perfectly with either spacers or a wider offset wheel
[ QUOTE ]
Adam,
I have 15mm rear spacers on my Golf Anni.
I'm using McGard 28017 on the rear (45.0mm) and McGard 28018 on the front (26.7mm).
There is a groupbuy on at uk-mkivs.net for them /ubbthreads/images/graemlins/wink.gif
[/ QUOTE ]
Thanks mate, will prob order a set from there and flog mine on.
Cheers!
Adam
PS: Your old car made 271BHP on the rollers today .. v pleased /ubbthreads/images/graemlins/smile.gif
Are original wheel studs ok to use with RS4 reps (From Rochfords). Cause Ive just checked and only about 10mm of the thread goes into the wheel hub.
I the checked the old Avus wheels and the stud sticks out on the hub side much more.
Will this be ok or should I get longer ones?
Dont fancy a wheel coming off /ubbthreads/images/graemlins/shocked2.gif
[ QUOTE ]
[/ QUOTE ]
Anybody?????????
688
718
428
647
