AGU figures
jay1601
kingsclere
had a bit of a search around on google, couldn't really find a 100% answer
i got a AGU lump, stage 1 map. but after a bit up power really.
looking at buying a K03S with a custom map to suit
question is, would i also need better injectors. and what is the real max figures i could see with a K03S on an AGU
thanks for any advice
Jay
No u don't need bigger injectors it's just a straight swap but u will need a silicone tip, I have a ko3s agu and made 232bhp with a custom stage 2 from R-tech
As said, to get teh most from a ko3S you need a turbo back exhaust, TIP, and FMIC.
You don't need any upgraded injectors, FPR, or MAF.
realistic max is around 230bhp, with between 240-260lbft, although that's not a held figure, more of a spike at 3500rpm.
Still mighty nippy though, and a massive step up over a stage 1 ko3 setup
what kind of things would you need to stop to much power hitting the front wheels and spining like a *****..
yeh yeh feck all wrong with my driving, who puts a fecking post on a bridge ne way.... i mean honestly..
Decent tyres and it'll put the power down just fine.
1st gear is a bit useless at full throttle, but after that, it'll be fine
Agreed 1st is to aggressive to get all the power down but 2nds where it's at
I would recommend yokohoma fir best grip but won't last long and toyo for nearly as much grip but will last longer
