Hi
I have a 2000 8L S3 with a pretty standard APY lump having covered 94K.
A month or so ago it started rattling between 1200 and 2000rpm only when warmed up and gets louder when the car was nice and hot, the rattle seems to come from the left of the head but doesnt do it all of the time when its hot.
So far I have had the rocker and cam covers off and nothing seems to show any signs of wear. I was suprised at how good the internals of the head were, the cam chain is under tension and the guide only has a small groove, so I think that can be ruled out.
I have changed the oil pump and pick up and replaced the oil with Synta for piece of mind, as I thought it could be down to low oil pressure but this hasn't solved it.
The serpentine belt and cam belt are both under tension and seated correctly and do not seem worn in any way that would indicate that they were the problem. Changing these and the water pump will be my next job
Anyone have anything else I can check, the rattle totally vanishes under 1200rpm and above 2000rpm, I'm stumped as is my friend who is a mechanic.
Thanks in advance
Alex
Thanks in advance
Alex
