steve bain
Morning all.
So my 1.8T A3 has started to clunk. heres the run down. Couple of weeks ago lowered in 50mm ish on coilovers and it slightly clunked when cornering hard left. (like this: clunk ...clunk ...clunk, to me it sounded rotational and was a good solid clunk) I assumed it was the driveshaft fowling the arb so raised it up 5mm and it went away, mostly, but still did it a bit
to stop this clunk i have now replaced all wishbone mounts, top mounts, new coilovers obviously, new drop links. i have inner arb bushes to replace too.
heres the odd bit! there are no visible marks on anything that would show that it is being continuously hit. the arb has rubbing as on full lock it grind on the driveshaft, but that is definately a different problem.
today it was awful! last night i drove for an hour on the motorway and today it was awful.
now it clunks when turning left or going straight. it clunks when i take up drive and let it off. and it is definately rotational.
my thoughts are cv joint or the drivers as thats were noise seems to be from and lowering it has just made the problem come to the surface. not sure if inner or outer.
or that my new wheel bolts are fractionally too long and are catching. although this feel ok on the ground but the extra weight of the car may effect it. dunno. but this has all happened since lowering.
any opinions or advice appreciated. If i can't fix it this weekend it will have to go to the garage as i can't keep driving it with the noise!
