Hi,
I'm in desperate need of some help. The roof on my 2006 (B7)A4 went down ok the other day but would not raise on the switch. I closed it manually using the key and procedure but now when i operate the roof switch the front of the roof will unlock and raise an inch or so...but then nothing else happens!
performed a manual open and close to see if it will reset but to no avail!
when i turn the ignition on the roof warning light will flash 10 times and then stop.
I have had VAG-COM on the car and it shows 1 fault found: 00830 convertible top control module (J256) 49-10-No communications-intermittent
i had the fault reset but still no luck opening or closing the roof on the button!
My next port of call is to get to the control module to check wires and connections (which i believe is behind the rear seat back) but i am struggling to get the seat out.
Any advice/help with this could possibly save my car from getting thoroughly wrecked with a very large hammer.
Thanks in advance for any help/advice recieved.
