my electric window on the drivers side has stopped working all of a sudden and i want to check the switch out but im not sure how to get the card off it is a audi a4 2000 fsi 2003 model many thanks.and can the computer be reset as well?
thanks for the reply would it be the same thing to the drivers side when it says use screwdriver to prise out window lifter switch
module from underneath through hole does it mean through the speaker hole? coz i was wondering if i could get the switch modules out without taking the panel off ? thanks graham/
Doubt it's the switch, far more likely to be the wires breaking up inside the rubber door/jam sleeve,wear caused by opening-closing, driver door goes first as it gets the most wear !
