can be removed in instrument cluster softcoding, had to do mine when i fitted the s4 brakes as pads didnt have wires
ross tech states up to 1999? worked on my facelift
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below [Do It!] Look at the first two digits in the coding. Add the values for the options together to get the correct coding. 00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
