DaveA3
Audi A-Trizzle!
Hi Peeps
I'm looking for some help regarding a few pipes. Long story short i had some boost leaks and put some silicon tubing in as a temporary measure so i could drive the car.
I wanna get some stronger ones from forge or anyone else or even dealer possibly. The silicon ive used isnt very strong and is quite flexible and im worried its sticking together with high vacuum. plus one of the smaller pipes is loose as the original had a reducer on the inside to help keep it tight.
#1 This pipe had cracked and split all over the place it was half rubber and half metal and worked its way around the side under the plastic bit. This pipe is loose on the bronze nipple part at the front of the manifold. Need a solution to stop any leaks. The original had an extra sleeve to hold it all tight. but again it was split.
#2 these pipes came in 2 parts one either side of that mystery valve. any ideas on what they are called and a suitable replacement? forge or oem? any info would be helpful
#3 what is that valve called and can it leak? r-tech mentioned i had a valve which was leaking he said its common for them to leak on these engines. dunno if its this one or the one in the PCV system underneath (if thats where it is)
please excuse my ignorance and my messy engine bay.
cheers! :icon_thumright:
Dave
Dave
