Hi
Got a dash cam for xmas and just got round to getting the hardwire kit so I can wire it into the fusebox instead of the 12V socket under the arm rest.
Whats the best/easiest method to run the wire? I was going to hide it up behind the mirror (the camera) and run the wire under front lip of headling and down the passenger A pillar and into the fusebox.
How easy does the trim remove on the A-pillar? Any certain method to doing it at all?
Is there any reason why I cant just tap into any of the fuse locations? I know will be permanent live, but will have to see how the camera suggests wiring up.
Is there any switched live fuses in that area?
Chris
Chris
