Has anyone else who's bought a new car had this? I was search 3 days before I picked up my car!! I didn't give permission for this to happen?! I obviously did for the initial search but not a 2nd one!!
That's EXACTLY what I didOn a mortgage application a search is performed at application stage but also commonly just prior to release of funds in case the applicants financial situation has changed e.g. Post application and mortgage approval they Take a new S3 on finance
Oh OK, thought it was a bit strange!! Does having a car on finance really have that much of an impact on your mortgage application?!
Borrowing upwards of £40k is madness that must be a very large monthly payment indeed?Yes...it affects affordability in that a sizeable chunk of your income is going towards repayments, and also remember you are borrowing the entire amount of the car. If it's something like an an S3, you are borrowing upwards of £40k....
Not quite that "simples".Im not sure this is a problem. The monthly payment is just that, it shouldnt be an issue with a mortgage unless you are unable to afford. If you are are unable to afford both, then of course you will be declined. Simples
The lenders test is not whether you can afford the mortgage repayment as it is now with the car payment on top.
The lenders test, as required by the regulator, is whether you can still afford the mortgage should interest rates rise.
Given mortgage rates are at an all time low, and the debt is for perhaps 30 years , and that wage growth is depressed, this prudent policy makes sense and protects the borrower just as much as the lender.
That said, there is of course nothing to stop the borrower taking out the mortgage and then merily spending away after the house purchase completes.
I think the point I'm trying to make is that restricting your borrowing power on buying a home due to taking finance out on a brand new S3 isn't the wisest choice you can make.
You could very well afford the repayments of both the mortgage and the S3, but the lender might not let you borrow as much due to the fact you have such large finance owing on a car.
I would much sooner stretch myself by borrowing more against an appreciating asset, such as property, rather than have to settle for a cheaper property due to the fact I have a massively depreciating asset to finance along side. All about priorities IMO, but that's just me...
So if you can get a mortgage for 200k you'd max yourself out at 200k? Having a car on PCP shouldn't make a difference for affordability.
At current interest rates, and with the return on property in my neck of the woods, absolutely.
They might be willing to lend you £200k without the car finance, but much less with it.
Car will cost you far far more per month and will end up costing you thousands at the end of the agreement. Conversely, that extra you could borrow had you not had car finance would enable you to buy a better property and will very likely increase.
But yea, if they are willing to lend you what you need with or without the finance, then there is no issue. But it does affect your ability/amount you can borrow on a mortgage.
