Dont believe it will fit due to different turbo (different part number too). I have one off a mk5 golf and the left headlight 'scoop' is different so it has a custom bracket, I have xenons so that probably affected it fitting.
Also, where did you get the RS3 trims from and how much?
Hi all, i am trying to buy a twintake for my a3 2.0t, i have seen one from an s3 will this work with my car as i know the s3 has a different turbo?ThanksChris
If you really want one of these,the best thing to do is to ring Forge and ask if it will fit......otherwise,there are plenty of intakes which perform just as well,but don't need two filters.
