Wing mirror side repeater fitment
s1mon02
hi, does anyone know how to replace the side repeaters on the wing mirrors? Any video tutorials would be brilliant thanks
Chilli_Pepper91
I’m about to do this job in the next few days Im going to use this video as a guide to get access to the repeater
Will let you know how it goes
Genius
That wont work! That's for an 8V the repeater is built into the wing mirror cover on the 8P.
You need to remove the glass (just clipped in) plus the 2 wires for the heating element, then remove the motor (1 screw in the centre plus a wiring connector) then there are around 5 additional screws if I remember correctly then you can unclip the mirror cover and one wiring connector for the repeater. The repeater will then slide out of the cover and you can slide your new one in, needs a bit of force to click into place. Also plastic trim pry tools are really useful for this job. Screws are tiny Torx ones cant remember the sixe
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
As @Genius has said your video is for the wrong model if your looking at doing it via an 8P you might want to follow the link already posted
Chilli_Pepper91
Cheers for the heads up! So yh I won’t be using that video hopefully it goes smoothly.
