  2. Dismiss Notice
Wheel sealant for winter use recommendation wanted
dp_motley Oct 5, 2019
  1. dp_motley
    dp_motley 2019 A3 35TFSI S line
    1,292
    506
    Hello everyone! What rim protective sealant/wax would you recommend for winter wheels? My new winter alloys (v2 rotors) have the diamond cut that isn't covered with any clear coat. I don't have time and money to apply the clear coat, so I think I should try and protect the wheels with a kind of sealant/protector/wax. There are many products available online and all of them have mixed reviews. My main concern is road salt that can destroy the diamond cut. Also, as the rims are satin grey, it would be nice if the end result was not shiny. I would appreciate your recommendation.
  2. Avatar
    snack-media
    Advertisement
  3. RS03_SEN
    RS03_SEN Registered User
    577
    364
    Carbon collective Platinum Wheels?
    Sent from my GM1913 using Tapatalk
    DW81 likes this.
  4. Adam14
    Adam14 Registered User
    2,262
    2,099
    Carbon collective platinum wheels are very good! Or the Gtechniq offering C5 I think it is?
    Sent from my GM1920 using Tapatalk
    dp_motley likes this.
  5. dp_motley
    1,292
    506
  6. NevMan
    NevMan Well known member
    6,732
    8,824
  7. Bulldog
    Bulldog Registered User
    846
    663
    93
    Gtechniq C5
  8. JWAM
    JWAM Registered User
    109
    99
    I put 3 coats of car pro cquartz UK 3.0 on my winters and they did well. I think in a fit enthusiasm I also did 2 top coats of gliss. I have c5 on my summer set and think the car pro ceramic seemed to hold up a bit better - but I did use more layers for the car pro. Not much in it tho. Really easy to apply both products. Personally I'd go for a ceramic over a wax for wheels. The consumer grade stuff is almost fool proof as long as you follow instructions.
  9. dp_motley
    1,292
    506
    Thank you guys for the recommendations! I read about all the recommended products, all look great. After all considerations, I'm close to purchasing the carpro dlux. The C5 looks great too, as well as the kamikaze, but the carpro dlux is available in Denmark and less expensive. I'll try it on a set of my winter wheels and hope I won't screw it :)
    NevMan likes this.
  10. Bristle Hound
    Bristle Hound Moderator Staff Member Moderator
    10,940
    16,179
    @dp_motley - Planet Polish Wheel Seal & Shine gets my vote
    3 coats 20 mins apart gives around 6 month durability
  11. dp_motley
    1,292
    506
    According to the title of this product, it makes your wheels shine. My wheels are matte grey and I want to keep them matte.
  12. Avatar
    snack-media
    Advertisement
  13. Bristle Hound
    10,940
    16,179
    @dp_motley - I’ve used this product not only on gloss black & silver alloys but also on Matt alloys that are found on the B8.5 S4’s
    Doesn’t make Matt alloys shine lol
  14. jassyo06
    jassyo06 T-Cut King !
    19,711
    40,351
    Your wheels will have a clear coat on them a matte one
    Go for a ceramic all others aren't durable enough nor give you anywhere the protection a ceramic does
    NevMan and dp_motley like this.
  15. dp_motley
    1,292
    506
    I don't want to scratch in order to check, but if there any clear coat, it's really invisible. Don't forget that I have replica alloys and they can be different from the oem ones. But anyway, I'm going for a ceramic.
    NevMan and jassyo06 like this.
  16. dp_motley
    1,292
    506
    I bought CarPro DLUX and was going to apply it this weekend. But then I thought that I got new alloys, no tyres were fitted yet. I thought of applying the ceramic coating first then fit the tyres. But would the balancing weights stick to the ceramic coating? Also, when tyres are being fitted, they rub the rim. Can it remove or damage the coating? Someone recommended to fit the tyres first. What do you think, guys?
  17. tcardio
    tcardio Registered User
    1,456
    548
    no brainer mate! Someone else takes off the wheels and installs tires, then you clean them off the car so you can get into all the nooks and cranies and then coat them on the ground and let them cure for 24 hours and then someone installs them. I usually have my tires installed on a late saturday and then tell the installer I will pick up the car on Monday so they dont charge rack time
  18. JWAM
    109
    99
    I'd do the coating after tyres and weights fitted. At least that's what I did!
  19. RS03_SEN
    577
    364
    They're gonna need cleaning after having tyres fitted anyway so hold out till they're done. No point cleaning twice mate.
    NevMan likes this.
  20. dp_motley
    1,292
    506
    @tcardio , @JWAM , @RS03_SEN , thank you guys! I think I should use your experience and coat the rims after the tyres fitted.
    Before, I thought of coating the alloys before the tyre fitting because they are clean already. I thought to wipe them with carpro erasure and ceramic coat right on a kitchen table in a warmth of my house and let them cure in a living room for a day or two. I didn't want to bring the tyres inside of my house and it's rainy and windy outside. But I don't see another option than to follow your advise.
    P.S. what if I coated the rims first, than used masking tape to protect the coating where it could be damaged in a tyre shop? Agree, I'm overthinking :)
  21. NevMan
    6,732
    8,824
    Definitely fit the tyres 1st then coat mate. Tyres will be new so not going to make house dirty. Get them fitted, give a good clean (to remove tyre fitting stuff..whatever it is), and then clean and coat alloys. Take your time and do small sections at a time, and go with at least a couple coats. Protects alloys and makes cleaning so so easy
    JWAM likes this.
  22. JWAM
    109
    99
    As @X3man says, tyres will be clean when new. Still worth lining them up outside and scrubbing the faces a few times with degreaser or a wheel cleaner of your choice (surfex HD at either 5:1 or 10:1 as the wheels and tyres are new; or bilberry wheel cleaner at 5:1 are my go to) to remove the releasing agent will be easier to do than when fitted. You'll also make light work of any remaining tyre sealent the fitters get on the wheels. With the releasing agent off the tyres (wash till the degreaser/cleaner is foaming without a brown tinge) any tyre dressing will last longer and be easier to apply off the car.
    Now its getting cold you'll get more reliable behavior from the ceramic coating applied indoors, they takes ages to 'flash' and be ready to buff in the cold and I suspect you may be outside the recommended working temp if you apply outside on cold wheels now.
    I did mine in the dining room. Wheels on old towels for the coating and actually didn't make any mess. I left the wheels/tyres in the house for a day for temp to come up before the coating and then for 24h or so after I finished. It was fine! Even my wife didn't complain; (acid test!) good luck, it really is quite straight forward.
    NevMan likes this.
  23. beanoir
    beanoir Large Member
    2,171
    32
  24. Bulldog
    846
    663
    93
    I just topped my C5 up with 2 layers of C2v3 hopefully get me through the winter months.
    Radford212 and NevMan like this.
  25. Nickyc
    Nickyc Registered User
    247
    86
    Do they still make this stuff ?
  26. Neil Woodburn
    Neil Woodburn Registered User
    197
    298
    Nickyc likes this.
  27. RS03_SEN
    577
    364
    What car is that???
  28. Bulldog
    846
    663
    93
    Radford212 and RS03_SEN like this.
  29. dp_motley
    1,292
    506
    Put one layer of carpro dlux this evening but didn't have time for a second layer. From what I read/watched, the second layer should be applied one hour after the first one. Can I apply the second one tomorrow, after approx. 20 hours? Would it adhere to the first layer, already cured to that time?
  30. Tonto1977
    Tonto1977 Registered User
    57
    67
    I got mine ceramic coated when the car got done.
  31. Tonto1977
    57
    67
    SiPie likes this.
