Hi,
I jacked the car up yesterday using the stick jack supplied - I was swapping some tyres around.
Anyway, on a flat surface the passenger side lifted up relatively quickly - wheel clearing the ground by a inch. However on the drivers side the jack needed it’s full extent to get the wheel lifted off the ground - a far more noticeable drop compared to the other side by quite a margin.
Anything that sounds wrong or should concern me? I’ve tried to research shock absorbers as that’s what can normally be at fault... The car isn’t spongy or bouncy on either side and reacts to bumps in the road normally. However I believe it’s an item covered under warranty so if I need to I’ll take it in to Audi.
Thanks!
Thanks!
