in which case, as always
, I defer to your first hand knowledge. The thing that was putting me off was a historical one from my impreza days where coilovers were all street and crashy but given the fact that if I went down the route of coilovers I could effectively kill two birds with one stone
Refresh the shocks and springs in one go and as a cheeky side bonus, lower the car by a slight amount . And I mean slight as I hate the lowered look with a passion, dont want to go back to scraping when going over speed bumps etc.
So with that all in mind, then yes please do your worst
Coilovers, it's a bit of a dirty word to so many owners and to be fair a lot of owners that have had bad experiences with them fitted may be due to poor quality units or less than ideal specs units for the intended usage.
In the past, i'd been put off coilovers by so many owners complaining about them, but it wasn't until i looked into it further that a clear pattern emerged that one needs to choose carefully, quality and intended use are key for getting a setup that suits your needs.
B7's have pretty poor dampers and spring at the best of times so changing them will always be a massive improvement.
Having tried several fixed rate spring/damper combo, the setup i removed 12 months ago, Bilstein B8's with H&R 45mm drop springs were excellent, i really could not fault the ride quality and handling, on a different level to the OE items, but being an Avant the rears always sit just a bit lower and i wanted to have a bit more control over rear ride heights, going coilovers was the obvious route.
Having looked at what was available and owners' feedback on numerous kits I choose KW's , not cheap at £1400 for all four corners.
Given the market place has a vast array of offerings for the B7 platform some cheap which I'm not convinced are the best option, mid-range offering are good , high end can be just overkill.
The kw's i fitted are superb, really nice ride quality, handling is spot on and build quality is very good and should outlast my ownership.
The added bonus for me is the ride height adjustability, i didn't want a silly low stance, just something midway, and I've achieved that without compromising ride quality and handling.
I'm not saying cheap units are bad but build quality can be less than ideal and spring rates/damping can be less than ideal, that said you can pay silly expensive amounts for overspec'd kit .
£1400 was more than I wanted to spend but in reality, it was the correct choice for my situation, but you'll find something suitable i'm sure , AP do well rated kits as do raceland.
buying another set of fixed height springs /dampers then deciding they are not what you wanted is just wasting your cash.
