Ricky Burrows
Ricky there a lot of testers that wouldn’t even now of that rule . I do but I think my car would pass . Maybe but I failed it last year on emission as the cat wasn’t fitted lol .
Lol yeah you kind of need one of them ha, mine just had the mot with the 034 hfc and it went through no problems, few people have said about issues on emissions with them fitted but mines ok (for now) fingers crossed lol
WOMBLERULZ
Mines due at the end of the month and I’m now running the 034 cat with a 3 inch down pipe in non res miltek but still got to fit k04 hybrid when it’s ready . But as blocks smokes I’m got some 83mm wossnor pistons and som 21mm pec rods . Heads going to have new valves and guides etc so it’s going to be a pukker motor . So finger crossed when it’s being rebuilt I’ll fit final bits . S3 injectors and rs4 valve . Already fitted new hpfp as old one leaked . I would mot it myself but off work atm but still have to do 4 hours online training for mot classes 1,2 and another 4 hrs for 3,4 . The joys of mot’s lol
WOMBLERULZ
Ricky as I read the info if vehicle is ref before 2009 it doesn’t have to have Headlamp washers . And it can’t be failed if not fitted ...
WOMBLERULZ
Official mot manual
Ricky Burrows
Sounds like your doing a fully built engine then is the ko4 hybrid a tte420/480 or something different? That's handy to know about the xenons I might just bang in some hid kits in mine and mrs car then that's always put me off so that's handy cheers mate :icon thumright:
Alex Holmes
Yeah that's a bargain where you finding all these and the 18z you said were cheap you must be taking all the cheapys lol, I had a look out after the car got hit I couldn't find a set of xenon's for less than £4-500, yeah your right is one of those wait till a bargain turns up kind of thing I guess, as for mot testers i seem to fall out with every mechanic so that's a task in itself lol
Its just pot luck i think! Its also very difficult to find a set that aren't damaged too! Mine were fully intact but i did worry when i saw the packaging they arrived in as i expected them to get broken in transit.
Get one in the family mate, no issues then lol
WOMBLERULZ
The headlamp must be originally hid . Retro hid and led is a failure ...
Stuart Bennett
I’m in Bristol mate.
Tried Interpro, they won’t touch VAG cars.
Badger5 prefer the 1.8T engine, not so keen once they found out it’s a Quattro TFSI.
Tried Avon Tuning, they won’t touch it.
Retro Resus use APR or Eco Tune for their maps. We’ll see if they get back to me.
Might try TSR in Bridgewater. They use Revo and have a 4WD dyno
If your in the south west like me you need to get in contact with Bevo tuning he does all sorts and knows his stuff! Look him up on Instagram and you can see the work he does
I'm Just Rob.
Moderating or something,
Staff member
Moderator
Gold Supporter
Today i transformed a very mucky b7 avant into a spanking clean one, then it snowed .....what a waste of time, well never complete waste of time as one has to keep winter grime at bay.:yes:
boffin486
Well folks, not today (last week), suffered the ignominy of requiring a breakdown flatbed to get me home.
The reason for this?
Driving along around 40ish in line of traffic - suddenly a tapping noise appears from front end that VERY quickly became a banging noise with serious steering vibration. Unable to stop instantly as in a line of traffic. Luckily I knew there was a layby about a quartermile further on so was able to pull in to that.
A quick visual inspection - nothing obvious or visible but car too low to really see under it very well. Called the AA, waited about 45 mins for van to show up. I explained that it sounded like a wheel bearing had collapsed. AA man jacked up car, disappeared underneath, waggled & tapped a few things & determined the D/S Driveshaft outer CV joint had broken. It's a Quattro so can't be towed. He ordered up a flatbed recovery. Waited another 2 hours for that to show up (had to run engine to keep heat up as it was ****** freezing).
Meanwhile got onto EuroCarparts on the phone & luckily they had a front CV joint in stock so called up me old man who went to get it. Recovered back to my dads (where I do all the work on my cars), got car up on ramp, driveshaft off, into garage, changed the CV joint over, back on to car & problem solved.
Took till around midnight though to finally be wheels back on road. You can see in pic that the CV joint cage had broken & one of the ball bearings came out. There was no warning this was coming - it just happened very suddenly - glad I wasn't going a lot faster at the time!
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Not a good day then chap, but you did well to get it sorted out as quickly as you did.:icon thumright:
Reminds me of the CV joint episode I had last may, my nearside shaft came completely out of the joint leaving me without any forward or backward movement.
Luckily it was only the clip that broke and a boot ripped off otherwise no damage.
Mine was the circlip that holds the shaft in the joint, went ping when doing a right turn in a car park.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
I suspect you got through as its a new cat tricky, not sure it will be so easy as it ages.
Ricky Burrows
Finally got my black optics grill on and the alignment sorted. What a PITA the bumper is on these cars, safe to say I wont be removing that again unless I really have to! (I know I'm missing the S-Line badge on this pic :))
I blacked the number plate holder on my optics grille have you thought about doing the same? It defiantly all blends in better once its black :icon thumright:
Ricky Burrows
Xenons chaps! Don't think I've ever heard someone say they regret doing it. Totally changes the look of your car also
Im all good with my poverty spec halogens :icon thumright:
I'm Just Rob.
Staff member
Moderator
Gold Supporter
I'm happy with the halogens if it means I never have to take the front bumper off again
First time is always a steep learning curve, second time things are much better , after that its easy peasy lemon squeezy..:thumbs up:
Also depends on which method you use, the quick hardway way or slightly longer easy way.:yes:
Chrismawa
It's more the faff on removing the wheels etc, and then the alignment issue.
Dan_Avant
Ordered a new thermostat and pipe that links to bottom connection.
Also ordered a new valve cover, gasket and bolts as mine is leaking all over the place....FFS!!
There’s always something going on with these cars
Chrismawa
Front bumper can be taken off with taking wheels off.
Have done it a number of times now
Yeah I know but its almost impossible to move my arch liner out the way and in the process decides to take the paint off on the wing edges. So to prevent this I need to remove the whole liner.
tr7
You only need access to the bolts holding on the bumper, you can get away with peeling back part of the liner closest to the front bumper to get an extension in there.
Just turn the wheels the other direction each time you go to each side
i3oricua
Cut a hole in the arch liner that allows you to access the bolts. Make the holes nice and clean and fairly small and i think you can get away with not having to remove them every time
Sent from my KB2005 using Tapatalk
Ricky Burrows
I've also never taken the wheels off to remove the front bumper, id rather man handle the arch out the way and just chuck my fist down that tight hole to get to the nuts........
Dirty bas**rds lol
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Well i'll throw caution to the wind then, i just cannot be fighting with the arch liner and limited space with the wheels on , i just take the wheels off , it doesn't take much longer and gives so much more room to get at them.
Ricky Burrows
Time you jacked up both sides and removed wheels id have the bumper off so id have to disagree its as quick, its not hard to pull the liner back a bit with wheel turned in, the liners already loose anyway from the two torx holding it to the front bumper anyway, really is no need to remove the bumper, but each to there own :icon thumright:
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Yep, all down to personal preference Ricky.:icon thumright:
That said when the wheels are off its a good opportunity to give the calipers a good clean along with the wheel inners.:yes:
I'm Just Rob.
Staff member
Moderator
Gold Supporter
nothing worse than mucky looking 18z's
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Replacing those Relays 644 has totally changed my car . And I will definitely need a better clutch set up when the turbo comes lol
Glad it helped sort out the initial fault codes chap, new relays are a noticible replacement.
Ricky Burrows
Yeah calipers lets not talk about them i scratched all mine taking that stupid clip off not long after i painted them to change the front discs and pads, something else on the to do list in summer.
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Fair enough then i won't mention calipers anymore today.....
But what about a pic of some nice Red ones then.....:yahoo:
Ricky Burrows
I'm Just Rob.
Staff member
Moderator
Gold Supporter
Not far off Ricky , that was them a few years back now but they have kept there finish very well and i do clean them properly on a regular basis.
My wife says I'm bonkers cleaning the inside faces of the wheels and calipers..lol
Ricky Burrows
I thought i was mad taking wheels off both cars every year and jet washing all in the arches and suspension ect you Rob take the game to a new level lol i salute you
