The First and only touran TFSI quattro there is, and as far as I know also the fastest touran there is.
Olly Bartlett's VW Touran TFSI Quattro TTE420 – Tuned to 400bhp 376ftlb
Its curently up
Forsale.
To summarize Olly took a mk1 (53 plate) touran FSI and upgraded to full S3 engine / box / ecu / running gear inc quattro / subframes etc, then upgraded engine components coupled with a TTE420 brand new hybrid turbo to make the above figures (more to be had from this set up in the region of 420/420) Along with this, brakes, arbs, suspension etc also was upgraded.
The outside has been updated with full 2011 touran front end with all new genuine bolts etc, genuine vw skirts and rear valance, 2011 touran door mirrors, brand new door strips and window rubbers along with replacement rear bumper and excellently finished fresh paint work and set of 5 genuine helios VW 19” alloys
Upgrades from the original touran spec include; auto lights with come home / leave home function, vw alarm/ immo with motion sensors and siren with USA tone, auto wipers, dual zone climate control, mfd2 stereo, roll down windows on key and cruise control
The interior has had a few upgrades too including retrimmed GTI steering wheel, Golf GTI (mk5) clocks and pedals, TTRS gearknob, chrome tip window switches, 2011 touran vents, MFD2 dvd stereo, leather handbrake, footwell lights, touran sport leather seats
Every effort has been made to make this car look and feel factory fit, with the best parts used and very well put together, it’s hard to put a price on such a thing being so unique but I have arrived at this figure which is a lot less than it has cost me to build (inc free labour) just parts alone
This is a get in and drive vehicle, no issues, no warning lights, EVERYTHING works as it should and is a joy to own, Olly would like to keep it but needs cash for the next project so unfortunately this has to go.
Shell is on 115k 1 previous owner with history, 12 months MOT, engine was low (60k ish) miles when fitted including new cambelt / aux belt, water pump, everything else was also sourced from low mileage donors or replaced with new, there is nothing left of the underside that is original touran
All the below has been fitted / changed in the last 6k miles
2008 S3 BHZ TFSI complete engine
155 FPV
G rev dv
upgrade HPFP
3.5" custom decat downpipe
3” custom cat back
Magnaflow 3” rear box
Peron FMIC
Helix organic clutch and LUK DMF
Revo intake
R-Tech remap - 400bhp 376ftlbs
TTS engine cover
6.6 bar fuel filter
S3 6 speed gearbox with uprated forks
S3 driveshafts
S3 subframe
S3 alloy hubs and wishbones
Super pro camber balljoints
Powerflex wishbone front bushes
Powerflex anti lift kit
New golf GTI engine mounts
Poweflex dogbone bush insert
Vibratechnics small Dogbone bush
Golf GTI bulkhead heatshields / a/c pipes / clutch line
Golf GTI fuse / relay box / panel
Golf GTI battery box
Full golf GTI wiring loom
Twin horn upgrade
Twin pump / level sensor washer bottle
Heated windscreen washers
Foglights
Auto headlights
Auto wipers
Alarm system with siren / interior monitor / anti jack
Golf GTI clocks
TTRS gearknob
Golf GTI reduced size retrimmed steering wheel with red stich
Leather handbrake trimmed with red stitch
Dual zone climatronic upgrade
Mfd2 stereo - silver buttons with phone jack
Touran sport leather interior with tables and picnic function
Golf GTI pedals
TTRS intank fuel pump
Golf GTI pump controller
Golf GTI fuel lines
Golf GTI carbon canister
Whiteline rear ARB
VWR front anti roll bar
TTRS 370mm front brakes
S3 310mm rear brakes + splash shields
HEL black braided stainless lines front and rear
AP coilovers
19 x 8.5 helios wheels
Votex side skirts
Votex rear valance
Chrome tip window switches
Alu Auto headlight switch
Golf GTI radiator - new
Golf GTI a/c radiator - new
S3 abs pump
Footwell lights
Golf GTI wiper stalk
Golf GTI can gateway
Golf GTI column computer / slip ring / angle sensor
Golf GTI CCM
Golf GTI CEM
2011 touran vents
Quickshift
Glass wiper delete bung
2011 touran front panel
2011 touran bonnet
2011 caddy front bumper
2011 touran wings and brackets
2011 caddy headlights
2011 touran foglights
Touran stainless kick plates
Runner flap delete kit
2011 caddy fog light covers
Upgrade Turbo discharge pipe
Upgrade TB pipe
S3 complete rear subframe / diff
S3 propshaft and heatshields
S3 esp controller
S3 fuel tank with heatshields and dual sender
R8 coilpacks
TTE420 turbo
NEW PARTS
Discs and pads all round
Cambelt kit and water pump
Cam follower
PCV
Plugs
All fluids / diff / box / engine oil / coolant / haldex / brake fluid / coolant
Every external light bulb
ARB bushes
Track rod ends
Drop links
Sun sensor
Drivers door handle
Scuttle panel
Leather gear gator
Stereo fascia
Alarm siren
Matt set
Battery
Cruise control stalk and highline computer
C rev slip ring
Door window rubber
All front end bolts / clips / foams
Dirt shields
Bassface 17cm speakers and adaptors x4
Twin horns
