Artimus
Shortback
I'm getting fed up of looking for my printout of the reset instructions every few months, so for those without the TPMS switch I've parred the instructions down to the bare bones and saved them both as an image & a .txt note, so they're always in the car with me when my computer is.
Hope this helps someone.
Reset TPMS via VCDS:
With the ignition ON, Engine Not started
Select: 03 ABS Brake.
Select: Basic Settings - 04
Select: Group field
Key in: 042
Select: Go
Select Done, Go Back
Exit: VCDS, Turn Ignition off, Wait 1 second, turn Ignition On, TPMS should illuminate and extinguish after 1 second.
Initially it will report tyre deflation of around 10 psi or higher, but after 5-600 miles the system will be able to warn of a tyre deflation of as low as 4-5psi
