  2. Dismiss Notice
Super weird noise, can anyone help? (VIDEO)
Gvnnar Sep 9, 2020
  1. Gvnnar
    Gvnnar New Member
    Hello folks,
    Been searching threads and can't really find similar issue so hopefully someone is able to help. This being my first post I hope it's in the right space :)
    OK, so here's my cry for help - super weird noise is coming from ( what seems to be ) far side front wheel. Normally happens at really low speed, seems to disappear above 10-15 mph. Happens both in reverse and drive, different turn angles doesn't really affect it. Steering wheel doesn't wobble or behave weirdly at speed or at braking, car drives as it should except for the annoying noise. Noise happens irrespective of brake pedal position.
    Really would like some opinions and advice on what that could be before I shell out for Audi to advise me. Not a lot of love for local dealership :p
    Car is Audi A3 8V ( pre-facelift ) 2014 with Auto 1.8 (T)FSI Quattro at around 60k miles.
    VIDEO
    Ideas for far
    1) Stone or foreign object stuck between the plate and disc
    2) Brake pads / disc is warped / worn
    3) CV Joint ( unlikely due to only appearing at low speed )
    Thanks!
  2. Avatar
    snack-media
    Advertisement
  3. pburv
    pburv Registered User
    7,032
    13,757
    Exhaust shield maybe?? Or possibly brake disc dust cover loose
    Fatbloke likes this.
  4. CanadaA3wales
    CanadaA3wales Canadian living in South Wales - Audi A3 8V 150BHP
    998
    263
    My noise from that area was a slapping scraping noise and it turned out to be the brake dust cover bolt that got corroded and came off and was scraping, but I heard mine at 20mph - 30mph as well.
  5. JohnM100
    JohnM100 Registered User Gold Supporter VCDS Map User
    1,612
    864
    If it’s the chatter noise - agreed as also does it when stationary.
    pburv likes this.
  6. Craig_s85
    Craig_s85 Registered User
    9
    Is the noise there when in neutral if you rev the engine a little?
  7. josul
    josul Registered User
    363
    295
    Sounds like the chatter that you hear coming from a tree or bush in Greece. The tree cricket, you got one of them little guys in there?
  8. Wibbly
    Wibbly Registered User
    410
    203
    43
    Def sounds like something loose to me, rather than scraping, triggered by vibration from the engine.
  9. Bigjase88
    Bigjase88 Registered User
    279
    97
    I have just had to replace both front disc backing plates as they had corroded and were rattling about, one had 2 broken fixings the other just the 1, replacement backing plates were circa £40-50 from Audi and half an hour job a side to fit, caliper / carrier and disc off job.
    pburv likes this.
  10. bakedcorn
    bakedcorn Registered User
    I don’t think it’s brake related as the sound seems to exist prior to rolling. You have warranty left on the vehicle?
  11. Bigjase88
    279
    97
    The vibrations from the running engine will be enough to make the disc backing plate vibrate
    Wibbly likes this.
  12. Avatar
    snack-media
    Advertisement
  13. pedro61163
    pedro61163 Registered User
    272
    Definitely dust back plates replaced my ones last year £18 each Tps
