Use plastic trim tools to slide your lower hvac controls forward, put a towel down so not to scratch your mmi panel. Once hvac panel is off to side you can slowly pry up mmi control panel with plastic trim tools. You may need to remove shifter knob if you need more room but I doubt it, maybe just boot frame will suffice. You will have access to clean or at least get buttons from underneath. I recently changed my starter button for the red vereity so it was very similar removal.
