  2. Dismiss Notice
Start up judder, help!
jri91 May 3, 2017
  1. jri91
    jri91 Registered User
    47
    Audi a3 2.0 tdi 8p
    I have a intermittent issue when starting up my a3 however the car drives fine.
    On start up i have a judder and delay before fully starting. This doesnt always happen but sometimes it can be really bad.
    Ive also noticed that sometimes the radio doesnt automatically come on and sometimes i get light which shows a fault with automatic lights/rain sensor?
    thanks!
  2. Avatar
    snack-media
    Advertisement
  3. Jnsio
    Jnsio Registered User
    69
    Any idea how long it has been since the glow plugs have been replaced? Plugs would cause that kind of symptoms after they go bad. Also how old is your battery?
  4. jri91
    47
    I done a test on the battery as it has failed to start without a jump start previously but the voltage came back fine. I think it may be the orignal battery?
    I may start by getting the glow plugs changed?
  5. ab1702
    ab1702 Registered User
    855
    260
    If it doesn't start sometimes without a jump start then that only points to the battery. If it's the original battery its probably time for a new one.
  6. Jnsio
    69
    Plugs are a good place to start since they aren't very expensive and easy to replace
    If it has the original battery there is a fairly high chance that it will be on its last legs by now too.
    It could be the combination of a few bad plugs and a weak battery making the problem worse since you have had to get it jump started. Did you just check the voltage or load test the battery?
    Also the odd electrical stuff like radio not automatically turning on and fault flashes could be caused by a weak battery which is why I asked :playful:
  7. millsy4002
    millsy4002 Registered User
    296
    98
    Had a slimiest issue that took weeks to find, after I replaced the battery, starter, alternator, glow plugs, the end cause was a bad earth point. Not sure how many there is, not loads, I would unbolt them and clean them up, wish I'd knew this before replacing half the car
  8. millsy4002
    296
    98
    *similar
  9. Marek196c
    Marek196c Gilera Runner / A3 Sportback
    828
    the juddering is also on shut down? If yes check engine mounts. However IDK how your battery is still alive o_O
  10. jri91
    47
    No just on start up, How much should i expect to pay for new glow plugs?
  11. Shiz94
    Shiz94 Registered User
    106
    17
    Sounds stupid but I noticed mine juddering on start up only when filling up at shell switched to BP problem solved worth a try
  12. Avatar
    snack-media
    Advertisement
  13. jri91
    47
    Honestly ive noticed its not as bad when using bp, but still occurs, maybe the fuel tank needs a drain
  14. Shiz94
    106
    17
    Possibly but IMO I would try changing fuel filter if it hasn't been done in awhile see if that helps
  15. NHN
    32,018
    2,416
    Sounds like a power issue, what year is the car?
  16. jri91
    47
  17. Marek196c
    828
    battery checked?
    Try to put in accessory mode, let glow plugs warm then shut it down, turn key back (off) then turn into accessory mode again wait for glow plug light off, and try to start, see if that help a bit.
  18. jri91
    47
    What is accessory more?
  19. Marek196c
    828
    when u turning the key u got 3 positions, 1st when you pulling out the key or putting in is OFF mode, then you turning the key by 1 step and got all things on, like radio, dash, climatronic etc... this is 2nd position called accessory/ON mode, then you got 3rd position that triggering starter motor and cranking your engine, (witch will anyway automatically go back by itself to accessory mode).
    So accessory mode is 1st turn (and 2nd position) of key.
  20. jri91
    47
    Didnt make much difference bud
  21. Marek196c
    828
    but if it makes check ur glow plugs then, as well alternator worth checking
  22. millsy4002
    296
    98
    It will be earthing I bet
  23. jri91
    47
  24. jri91
    47
    Do i replace the earthing cable?
  25. millsy4002
    296
    98
    Check where your earthing bolts connect to the chassis. Not sure how many there is, google them. mine was in a garage for a week, replacing everything, costing a fortune, in the end they said one of my earth clamps was a terrible connection causing the same symptoms as you
    Shiz94 likes this.
  26. jri91
    47
    I had this problem on one of my previous cars and learnt a way of checking it. Ive used this method and dont think this is the issue in my case. Thanks for your help
  27. Jnsio
    69
    Checked plugs yet?
  28. jri91
    47
    I followed the glow plug steps as above and no luck
  29. Marek196c
    828
    check timing and injectors for advancing angle (hopefully I said it rightly)
  30. Jnsio
    69
    So you replaced the glow plugs?
    If that didn't help I would get it checked for any fault codes
    Could also still be the battery unless you actually stress tested it?
    If not it might very well be something to do with fuel injection or timing as stated above.
  31. Marek196c
    828
    battedry don t seem to be as well earthing because if it was battery it was cranking slooooooowly and took time, instead here seem to be some sort of injection angle problem
  32. jri91
    47
    Sometimes it does take longer then this to fire up and makes a noticable juddering rattle noise and shakes
  33. Avatar
    snack-media
    Advertisement
  34. Marek196c
    828
    check glow plugs and relay for it, as mentioned.
  35. jri91
    47
    Another video, seems to be getting worse
  36. Nessy
    Nessy VW + Audi mad
    1,359
    191
    Have you replaced the glow plugs yet?
    Mine wasn't the best of starters , even in warm weather, when I was led to believe that the glow plugs didn't really do anything....
    I replaced all 4 of them and starting was transformed.
    Having read horror stories about the threads snapping on removal I approached the job with a little trepidation but I needn't have worried.
    Because the glow plugs are bathed in oil near the camshafts on the PD engines ( under the cam cover of course!) they came undone easily, the only thing I had to buy was a slimline long-reach socket to unscrew the plug ( from memory think it's 7mm?).
    I used Beru ones, identical to the Genuine Parts Beru ones that came out which cost around £43.
  37. Jnsio
    69
    A good and easy way to avoid snapping plugs is getting the engine hot before replacing them. I usually try to drive for 15-25 mins with lower gears and higher rpm before attempting to get them out. After some bad experiences (damn mercedes and their long plugs) I now do this on every car
  38. Nessy
    Nessy VW + Audi mad
    1,359
    191
    Good point, I seem to remember that I did this on a hot engine too.
    I also recollect that a decent pair of long-nosed pliers came in handy to remove the power supply to the glow plug.
    The glow plugs operate at 4.4 volts IIRC which means it doesn't take much voltage drop if they're worn out etc to give bad starting.
  39. Rideen
    Rideen Registered User
    1,152
    369
    Any white smoke from exhaust when you start up? Is the car using coolant?
    Could be water in cylinders due to the engine being BKD...
  40. jri91
    47
    Abit of black smoke
  41. aqibi2000
    aqibi2000 Registered User
    953
    160
    43
    Check cam timing
  42. PeteS307
    PeteS307 Registered User
    12
    Hi, did you manage to get to the bottom of this issue mate? I have the exact same problem starting the car, but otherwise drives absolutely fine...and it's very intermittent seems worse if the car has been sat for awhile before starting.
    aqibi2000 likes this.
  43. Rideen
    1,152
    369
    To be honest I sold my 8P 2.0 TDI because of the same issue, but mine had puffs of blue smoke 10 sec after starting and weird metallic noises during that period, never got to the bottom of it.
