Has anyone sprayed their brake discs with a high temp clear lacqeur or similar to stop the rust from forming on the outer edges Spraying the outer edges only!!)?
Is it safe to do so?
cheers
W
Brake disc's rusting is a unfortunate side effect of the material they are made from, not much can be done with them as they will rust eventually no matter what you do to them
