Hi all
So I’m experiencing this slight vibration which I can feel in the car and the steering wheel when off throttle. There is no noise and it’s not that it shakes massively but just enough to know that this is not right - especially since I can feel it in the steering wheel. It’s very occasional which makes it a pita to track down.
It occurs during the below conditions:
I’ve removed my dogbone insert and the vibration is still there but it seems that it’s not as pronounced as when the insert was mounted (this could be placebo though). This makes me think it has something to do with the dogbone mount or the pendulum arm (more like the rubber bushing in this).
The car is still under warranty but I know that you guys in here tend to know more than the Audi mechanics so it would be beneficial if I could point them in the right direction with your help.
I will try to fit another set of wheels in the weekend just to make sure it’s not that.
What do you guys think? Any suggestions?
- When coming to a stop at a traffic light I would sometimes feel it when I let off the throttle and brake slightly while the car cycles through the gear, still it’s only in 3rd and 2nd I’ve experienced it. It feels like an uneven surface but I know that is not the case.
- When I keep it in 3rd and I accelerate hard from 2.000rpm to 4.000rpm and let off the throttle, without braking, then I can feel the vibration between 3.000rpm and 2.000rom when the rpm drops.
