Found some slight oil in my coolant tank. Is this most likely going to be the oil cooler?
A aiwa_yamaha Registered User Joined Feb 6, 2014 Messages 31 Reaction score 0 Points 6 Location NULL Feb 8, 2014 #1 Found some slight oil in my coolant tank. Is this most likely going to be the oil cooler?
MrLapou Registered User Joined Jan 3, 2004 Messages 1,232 Reaction score 121 Points 63 Location Lincoln Feb 8, 2014 #2 engine block or head gasket.
J judge Registered User Joined Dec 24, 2013 Messages 53 Reaction score 9 Points 6 Location Greens Norton Towcester Northants Feb 8, 2014 #3 Check if you have emulsified oil in the top of your rocker cover. If so probably head gasket.
C Chillout Registered User Joined Apr 4, 2013 Messages 610 Reaction score 51 Points 28 Location Aberdeenshire Feb 8, 2014 #4 judge said: Check if you have emulsified oil in the top of your rocker cover. If so probably head gasket. Click to expand... oil cooler maybe but not common
Tonka Toy Registered User Joined Dec 30, 2013 Messages 119 Reaction score 24 Points 18 Location Hertfordshire Feb 9, 2014 #5 aiwa_yamaha said: Found some slight oil in my coolant tank. Is this most likely going to be the oil cooler? Click to expand... Pressure test the coolant system or use the sniffer?
