My car (new March 2014) was last serviced in November 2016. I probably only do around 5000 miles a year, so what sort of time should I expect to elapse before it next tells me that it's due a service?
With your mileage you should service it every 12 months.My car (new March 2014) was last serviced in November 2016. I probably only do around 5000 miles a year, so what sort of time should I expect to elapse before it next tells me that it's due a service?
It’s what Audi say. I guess that service requirements are not only related to mileage. It’s not good to go years without servicing.Why yearly if he only does low miles? Am I missing something?
Agreed, but what’s the difference between doing low miles and having a yearly service or doing higher miles and having variable. In my head I’d have said your lower mileage driver is more suited to variable.
Confused.
Low mileage generally indicates short trips right. So this is time the engine oil isn't hot for long periods of times.
Ie... When my mum was working the commute was 5mins, 2? Miles. Oil wouldn't even be 50c. Which is bad for oil isn't it. So yearly service to get fresh new oil.
High mileage = assumes longer trips. Oil should be healthier etc.
## I know ****** all about cars and engines but this is my guess haha ##
IF that is th case then I think my car will be the exception to the rule. I have a 15 mile (30-40 mins) commute to my work and back again (so 30 miles each day), however I don’t do huge miles overall. The oil in my car gets up to and stays at temp on pretty much 99% of my journeys and yet it is on variable servicing.
Does anyone have the definitive answer on this?
I don't know if I'd take my own advice never mind make someone believe it hahaListen to him, he doesn't have oil in his name for nothing!!!
Spot on, it happened to a mate of mines son, he had a VXR Corsa and the engine went bang! They refused to sort it out as he'd missed his service by about 2 months!!! Cost him about £4,000 for a recon engine....very expensive missed service!However imagine a car that was 2.5 years old and it had a problem and needed to go in for repairs. If the car had done 10k miles but only 1 service then I'd imagine Audi wouldn't be too willing to do work under warranty?
Well apparently the oil interval can change depending on the quality of the oil, there's a sensor for this (said someone at my Audi dealer). As for the "service" (inspection) well.. Yeah. Most people wouldn't know.But if you buy a new car and follow the mmi recommendations, they would probably have trouble saying it was your fault.
It’s only on this forum that I found out about the two servicing regimes - I got nothing from Audi when I bought the car. If I hadn’t been on here I would have followed the mmi, which is set by default to variable on new cars,
The MMI interval will change depending on the type of journey and how the car is driven. I don't believe that there is any type of oil quality sensor in the engine. What parameter would it measure?Well apparently the oil interval can change depending on the quality of the oil, there's a sensor for this (said someone at my Audi dealer).
Just consumption rate would give you quite a lot of info - high consumption reflects driving style and/or oil quality. More fancy types might sense metal contaminants getting through or building up on the filter, but that's a lot more complicated than estimating volume over time.The MMI interval will change depending on the type of journey and how the car is driven. I don't believe that there is any type of oil quality sensor in the engine. What parameter would it measure?
I think we can safely say that these cars know how and log to some extent how they have been driven to calculate oil life.Just consumption rate would give you quite a lot of info - high consumption reflects driving style and/or oil quality. More fancy types might sense metal contaminants getting through or building up on the filter, but that's a lot more complicated than estimating volume over time.
