Warsuperior
Finally found out what chassis car has, FK au45 coilovers and most likely took to limit of -60mm since almost nothing fits below oilpan.
Please dont rape me but I havent actually ever adjusted coilovers or well I have over 15 years ago and I dont remember **** and car wasnt S3
Basics I know, Lift car up, take wheel off but what then? Do I need to compress spring? which way I move what collar?
I googled honestly for 2 hours and didnt really find similiar topic. I want to raise car about 30mm so I should just move it halfway to other way?
Tomorrow arrives K&N filter. Had to choose bit bigger diameter for inlet hole but I guess I use some plastic or something to cover the 9mm difference.Flange Inside Diameter 3.5 in (89 mm)
Flange Length 1.5 in (38 mm)
Height 8 in (203 mm)
Base Outside Diameter 8 in (203 mm)
Top Outside Diameter 6.625 in (168 mm)
JR filter was out of stock and would have taken 2 weeks to get it so I had to go for that one.
Ordered also steel undertray to protect engine&gearbox and that oh so weak oilpan.
If I have time and help, car should be running in 2 weeks.
Is it possible to use gears from 02M 1.8t a3 gearbox? the second gear on s3 is short what I have searched and my A3 accelerates with 2nd gear to 110Km/h(68Mph) when limiter hits (6800rpm)
EDIT: I found excel from badger5. Going to study it.
