S3 GTX2860R gen II build
So my intank pump cannot deliver the pressure.
Like many said and I myself also acknowledged: The pump is not very realiable and here we see it.
High rpm the pressure is dropping.
I cannot recommend AFP 265LPH pump anymore.
Inline pump is waiting, I just dont know should I put it to engine bay, or where fuel filter is and put filter on engine bay.
Anyone have any experience with those tiny inline fuel filter?
example : https://www.aeromotiveinc.com/product/10-micron-orb-10-black-fuel-filter/
Hi I already have an Ignitron on my TT. Great piece of kit,I have had it go into limp mode a few times when I have been playing with it, mainly on the Lambda when I was playing with the Lambda maps and set it a little to lean. Added a fuel pressure sensor and oil pressure without to many issues.
Those small in line filters don't filter as well as an OE item and wouldn't be my choice. In line pumps can be noisy , The best but not cheapest solution is a DW65V. In the tank no messing around trying to power a second pump or work out where to put it.
Reactions: hydro s3
Thanks for everyone helping me with this and following and commenting. Could not have done this without you :)
I read this topic from start bit and saw people saying Im going to regret turbo choice but I have to say: I have not!
It is amazing turbo, spools fast, pushes to limit etc :)
Ok only regret is that its bit too small because I got used to the power :D
Car is in daily use and has performed amazingly great when you consider that I build it :D
Thank you again <3
Reactions: IPG and superkarl
Thank you again <3
That’s why they said you would regret it for the sake of a bit extra on the turbo for a bigger one you have more power and every will always want more power, it’s been good watching this progress
There is plenty of information in this thread for anyone wanting to do the same as yourself. Been good reading your progress and glad your happy with the way you build it (even if it's not got enough power) good luck with the stroker build.
Couple weeks back, Car broke down.
I was overtaking a truck with wastegate spring pressure only and saw pop of smoke from breather side of car. Thought it was just some water smokes as it has done that before but suddenly loads of white smoke and 1cyl dropped off.
Car pushes loads of white smoke when accelerate and 1 cyl comes and goes. Most likely head gasket or wossner piston cut in two :p
I was actually expecting this to happen or the engine to break up since it has made lots of noise when cold.
Well we had tons of fun times with this engine anways :) and new engine is going to be fitted in following weeks.
Farewall old engine!
