they look nice @Rob2k68 I've just noticed that there is no grub screw on the discs!
are the OE the same?
Cheers ;o)
The countersunk screw holding disc to the hub is about 9.00 o clock in the photo.
Discs are ECS tuning 2 piece design with an alloy centre hat that bolts to the hub (which shouldn't go rusty!!).
Benefit over single cast iron disc is a 2.5kg weight save each on the front and 1kg each on the rear so 7kg total. Might help suspension a little with the reduction in unsprung mass. Will be fitting braided stainless steel brake lines at the same time and a full fluid change to Castrol React Performance dot 4.
oh so it is, what a d1ckhead!
they look lovely! suspect they weren't cheap mind?
i find the stock brakes pathetic! i borrowed a new A4, and the brakes on that walked all over the S3 brakes. I'm in two minds when i change my tyres in a few k, ill change my brakes, regardless that they are barely worn!
They certainly look the part! How often do you have to check those screws for tightness?
If you are worried about the screws coming undone give this thread locker a go we always use it in work secures the screw nicely and not too difficult to undo...Cheers ;o) Much improved initial bite so pleased with them thus far.
No idea - no documentation saying so but I'll keep an eye on them.
http://uk.farnell.com/loctite/243-1...20220718029&CATCI=pla-94018940771&CAGPSPN=pla
If you use 270 you will end up rounding off the heads of your screws.We sometimes have to heat up parts to get the loctite 270 to loosen up..270 might be better. It's got a higher temperature tolerance, higher breaking torque, and you don't need your threads to be surgically clean as it's tolerant of a bit of contamination too.
Exactly, the cyclical heat from the brakes will render anything less pretty useless in fairly short order. Of course rounding the heads is quite likely, but thats assuming you're ever going to take them out? Unlikely I should think. I'd be more inclined to make sure that they never came out at all.If you use 270 you will end up rounding off the heads of your screws.We sometimes have to heat up parts to get the loctite 270 to loosen up..
Pretty much a pointless discussion really as I should imagine ECS would have the appropriate adhesive on such a safety critical component..Wouldn't do any harm in asking I suppose..Exactly, the cyclical heat from the brakes will render anything less pretty useless in fairly short order. Of course rounding the heads is quite likely, but thats assuming you're ever going to take them out? Unlikely I should think. I'd be more inclined to make sure that they never came out at all.
It'd probably be worth asking ECS what they've used already.
Rob, have you got any pics of the back of these discs at all? I'm curious to see how ECS handles the differential expansion of iron and aluminium, and how it's transmitting so much torque through that joint between centre and rotor.
The front suspension is definately more forgiving and less crashy over small bumps and speed bumps with 2.5kg less unsprung mass per corner which is a nice benefit.
I know what you're saying but ECS have had these in production for a number of years now since mk5 Golf I believe and have them available on many models of BMW so I'm not overly concerned.
The difference in small bump compliance would definitely be one of the first things you'd notice. Similar to moving from heavy oversized aftermarket alloys to something smaller, forged, and wallet smashingly expensive.
I wouldn't say you need to be concerned, just keep an eye on them as with a lightweight centre and additional mechanical jointing, they're not as bombproof as the Audi OEM discs were. Discs and brakes in general, despite being quite obvious and in your face, are often totally neglected.
Hi I know it’s a old thread but I am looking at getting these. How have they been over the years? What do they look like now if you still have them?
They look great Rob, how much did they set you back if you don't mind me asking, and where did you pick them up?Now on my car fairly straight forward but you need a special tool for the rears :-
If you contact awesome gti they can order them as I asked in email.They look great Rob, how much did they set you back if you don't mind me asking, and where did you pick them up?
As well as a slight upgrade I like the idea of no more ugly looking visible rust!
It's the weight reduction I am after. Less rotational mass the more power to the ground.EDIT: misread your post, however the information below could still be useful for others so I'll leave it here.
As @Dandanfings says the Zimmermann discs could be a cheaper alternative to the ones described by @Rob2k68:
Front: https://www.qp24.de/car-parts/brake-disc/600-3243-52-zimmermann/1690556
Rear: https://www.qp24.de/car-parts/brake-disc/100-3309-52/1689162/brake-discs
Vag com as it’s electronic rear hand brake.Hi there,
You said you need a special tool for the rear brakes.
Please could you point me in the right direction
Hi there,
